84 Cutlass supreme rear brakes help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2007, 03:42 PM
cokeman277296's Avatar
I just bought a 84 cutlass about 2 weeks ago. Drives and runs good but it started making a god aweful grinding noise from the rear. It came from the driver side rear drum brake. I took the hub off and have a brake shoe came out, a spring, and 2 other things I have no ideal what thay are. Can anyone help me with this to get it fixed. I know Ill need shoes and new springs, and those other things that fell out look like some kinda adjuster. I've done several disc brake but never fooled with drums. Please help.
Old 11-19-2007, 04:13 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
If you take apart the other side it will be easy to re ~figure out what all fell apart,
it is the same~ but opposite
On drum brakes there are 2 different shoes one has less friction surface than the other there for it is "smaller"
The "smaller" one always goes to the front
You will need to look @ the wheel cylinders make sure the bleeders are not frozen up and not leaking fluid & get a complete spring & nail kit for both sides .
Next you will need to make sure the E brakes cables are not frozen up .
Same with the adjusters.
You will need to inspect the drums for damage have them measured.
I don't have pictures of that particular set up but the Chevy truck is very similar.
Post back with any more questions you might have.
R
"SlowRide66"
"Illegitimis non carborundum"
Old 11-19-2007, 04:16 PM
The bottom spring and the round thing beneath it is what fell out. The round thing beneath was grinded all to hell.
Old 11-19-2007, 04:18 PM
You got instructions by any chance.
Old 11-19-2007, 05:43 PM
Rob Keller's Avatar
Wiki Edits: 38
OK Read this article on how stuff works "Drum Brakes".
I have not read this yet .
I will return with My opinion on Do's & Do Nots of this article.
R
"SlowRide66"
Old 11-19-2007, 06:20 PM
Rob Keller's Avatar
Wiki Edits: 38
http://www.dippy.org/svcman/sm05b.html#SHOEINSTALL
Found here
You will need tools
Brake Spring Pliers
Small Flat head screwdriver
Brake Button Tool
"SlowRide66"
Old 11-19-2007, 06:25 PM
Rob Keller's Avatar
Wiki Edits: 38
Let me know if you run into a problem.
"SlowRide66"
Old 11-19-2007, 06:29 PM
Thanks Rob Keller. I got the tools I needs today will at the auto parts store. I got everything except the new adjuster kit which will be here when I got off work. Thanks for the sites you sent me. Ill tackle it when I get home. Im sure with what you've gave me I'll be able to figure it out. Its always nice to recieve help when You really need it. Ill yell at you if I get stuck. Thanks again and wish me luck lol. Cya
Old 11-19-2007, 06:45 PM
Rob Keller's Avatar
Wiki Edits: 38
I'll be here some where.
I guess I need to write a "how to " for brakes in the WIKI.
Nuthin there!
Be care ful take your time & think safety 1st be careful of the springs & stuff they can launch. hand & eye protection a must & use a liquid to clean the area do not blow it around
Remember do one side @ a time {sometimes I still have to do that } the broke side 1st.
R
"SlowRide66"
Old 11-27-2007, 08:05 PM
Rob Keller's Avatar
Wiki Edits: 38
Well . . . .how'D you make out?
R
"SlowRide66"
Old 11-28-2007, 07:54 AM
Really good once I got the first wheel done. That grinding sound I told ya about was the bottom adjuster. It was just laying there when I took it apart...lol Drives great now and Thanks for your help.
Hope you have a great Christmas!
Old 11-29-2007, 04:17 PM
Rob Keller's Avatar
Wiki Edits: 38
KEWL
You are Welcome
You Too
R
"SlowRide66"
rear disc brakes, ford 9" readdirections Suspension - Brakes - Steering 6 09-08-2006 08:16 PM
Cutlass Supreme HP? greasemonkey92 Engine 1 01-13-2003 09:37 AM
REAR DISC BRAKES BIGBLOCKSTANG Interior 1 10-30-2002 03:41 PM
305 Cutlass Supreme greasemonkey92 Engine 3 10-03-2002 07:50 PM
