84 gmc pickup with th350 lost power - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2010, 09:08 PM
I have a 1984 gmc short bed pickup truck. when i bought the truck it had a th400 transmission, well i lost 3rd gear so my dad gave me a 700r4 transmission out of his van when he blew the motor in it. I put it in my truck and i drove it around the neighborhood a couple times and it ran good and then on my way back home the transmission lost all power and the motor revs real high and the truck was barely moving. So i pulled it out and put a th350 transmission in the truck that my uncle gave me. I drove it around the neighborhood a couple of times and it ran good and then on my way home it did the same thing as the 700r4 transmission, but unlike the 700r4 transmission the th350 only has power when it is cooled down, once it gets hot it stops pulling but if you let it cool down it is fine....what could cause this?
Old 09-15-2010, 02:06 PM
SSedan64's Avatar
Did you flush the Trans lines & cooler when the TH400 went bad?
Did you have the TV/ThrottleValve Cable & Bracket connected and adjusted properly with the TH700R4?
For TH350, fluid Cooler in Radiator may be plugged. Brake Clean & compressed air works well. Flush in reverse of fluid flow.
Old 09-15-2010, 10:46 PM
yes
i did all of that i dont understand what is wrong with the th350 i worked perfect in the truck i pulled it out of, i even changed the seals the filter and the fluid...
Old 09-18-2010, 08:51 PM
Duntov's Avatar
Visit the NASCAR Hall of Fame
Well, sounds like history repeating itself. I want to stay with this one and see how it ends. Good luck
Old 09-18-2010, 09:03 PM
LATECH's Avatar
My oldest brother put a 350 in an s 10 and it would do the same thing. Turns out the rear end was out of oil and full of metal shavings
Acted the same way
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
lost all power sinaloas67chevy Electrical 0 07-09-2004 12:06 AM
Lost power assist !!!! 1970 GMC Truck digtaz Suspension - Brakes - Steering 2 04-16-2003 07:46 AM
Lost power wires scottgto Electrical 3 04-05-2003 10:04 AM
