For strip, I would use the worn struts with a lighter set of springs (6 cyl) and unhook the sway bar for track useage. Keep the OEM brakes for weight, make sure the control arm bushings are free and strut mounts are OK (adjustable would be nice for straight-up camber). Sub-Frame connectors and boxing the rear control arms (lower) will get you a cheap start-up. |
The car already has the front sway off. It has a 6 point roll cage. The rearend has adjustable upper control arms and the reason for the new springs is because the current ones are weak. The only negative side of the full drag launch kit is its stance. I am looking for a lowered sleeker stance while keeping its launching capability. For the front shocks, i suppose adjustable would be preferable in my case?
Mikey |
A properly set up rear end will launch with NO weight on the springs.... springs don't even have to be in there... they only hold up the car until the light turns green. |
If you are able to drive on the street without a sway bar, a front set of drag struts isn't going to make much difference. A set of adjustable (as in KONI) are extremely expensive to make a combination street/strip car in my opinion. You will get used to the slow lowering and harsh ride. A cheap (or used) front spring along with a shorter (possibly cut) rear spring will give it more strength and lower it also. You would have to experiment with used springs (and cutting) or go to expensive drag springs. |
The car currently has cut off 'old springs' to have the stance lowered.....basically i want the lowered stance but on new springs. I thought even though the front sway is off, it wont hurt having new springs installed for cornering purposes? The car launches pretty good right now with the setup it has, and has ran in the mid 12s on street tires. But if everything goes as planned, by next summer the engine is going to get more power....needing better traction at the rear wheels on launches. Another problem is that it could use better cornering capabilities. I am focusing more on the launching that cornering though...and i know i cant get the best of both worlds here...i am only looking for ways to improve the weight transfer on launches while keeping it somewhat streetable and manageable in corners.
Keep those inputs coming guys. Thanx Mikey |
| How to properly mate a GM pump to a Mustang II rack | Centerline | Suspension - Brakes - Steering | 73 | 10-31-2009 11:59 AM |
| Will a 390 fit or work in a 73 Mustang..... | onebadmerc | Engine | 4 | 12-08-2005 09:57 AM |
| sbc in 84 mustang | kthornhill | Hotrodders' Lounge | 29 | 05-26-2004 01:06 PM |
| Are Mustang II Crossmembers Safe? | Jon | Suspension - Brakes - Steering | 14 | 10-17-2003 12:43 PM |
| 84 mustang front clip | hapbsp | Suspension - Brakes - Steering | 1 | 12-29-2001 07:08 AM |
