Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '84 Renault Fuego Turbo Problems (Bosh L-Jetronic FI)
Old 06-17-2004, 08:10 PM
GTBaker's Avatar
GTBaker GTBaker is offline
The ECU is under either the drivers seat or passengers. You can't miss it...it's a big hunk of metal. Also check the ground wire going from the body to the engine...it's on the drivers side..I think. It's a big braided bit of copper.
I've owned one of these for a few years back in the late 80's. Very fun car...and yes...$$$ to fix if it went wrong on you.
Cheers
GTBaker ------ 2000 Echo 4 door 5 speed
[i][b]
The Acme Principle[/b][/i] - Everything falls faster than an anvil.
