84' S10 without kit starter problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2008, 12:24 PM
i have this 84 s10 and i have not been getting the right answer... i need to know i the 305 starter drive gear and a 350 ring gera are compatible... with tooth spacing or what not?
Old 12-28-2008, 01:08 PM
It is a fly wheel not a ring gear and yes it will work. I had kinda the same problem years ago and I had put the fly wheel on backwards.
Old 12-28-2008, 02:53 PM
Chevrolet Small blocks have basically two sizes. The 168 tooth and the 153 tooth. Some call the 168 tooth the 14 inch and the 153 tooth the 12 and 1/2.
305 and 350 starters will interchange as long as you put a 153 on a 153 and a 168 on a 168. Some applications are different as far as the room they take up ... but do basically bolt up. I like to use the small mini starters ... they are small, gear drive and are prone to resist the heat better than some original starters.
Old 12-28-2008, 06:10 PM
no i might be 16 but i do no the difference between a fly wheel and ring gear i have an auomatic.... there fore its a ring gear
Old 12-28-2008, 06:13 PM
Okay then so It's a ring gear?
Old 12-28-2008, 09:49 PM
Wiki Edits: 49
no i might be 16 but i do no the difference between a fly wheel and ring gear i have an auomatic.... there fore its a fly weel
Actually you have a flex plate. Flywheels are used with manual trans and a pressure plate and clutch. Some flywheels have a pressed on ring gear and some are one piece. Not being a Chevy guy I'm not sure if your flex plate has a pressed on ring gear or not but I would bet it does.
Old 12-30-2008, 03:00 PM
a ring gear is in the rear end
Old 12-30-2008, 04:37 PM
Wiki Edits: 49
If you are talking about rear ends, yes. However there is a ring gear that is part of a flexplate on an automatic or flywheel if its a manual trans. Not all flywheels/flexplates have a separate ring gear. Some are machined but most are friction fit which require heating the ring gear so it can be installed. Here's a picture of a Napa replacement flywheel ring gearfor a 1970 Chevelle 454 with a manual trans.
Old 12-30-2008, 05:12 PM
T-bucket23's Avatar
Wiki Edits: 26
On chrysler products the ring gear used to be on the Torque converter. An actually a flex plate was also from the old Mopar days, it was just plate that sort of looked like a big Y that the converter bolted to.
Chet
Old 12-30-2008, 06:10 PM
Wiki Edits: 49
True. The early fluid drive Chrysler transmissions (predecessor to the torqueflight) had a "flywheel" that included an integral torque converter which was basically all one unit. That said, since the late '50s automatic transmission "flywheels" have been called flexplates and you won't be able to find a "flywheel" for an automatic in just about anyone's catalog unless you use the term flexplate.
As an example, here are two searches on the Jegs web site. Note that the search for flywheel does not return any "flexplates" for automatics and in order to find and automatic "flexplate" you have to search using that term.
Jegs search for flywheel
Jegs search for flexplate
yet another post with starter problems 1989gta Electrical 10 10-23-2008 10:06 PM
mini starter problems gilbert773 Engine 1 10-30-2007 02:37 PM
Starter Problems Thumper II Engine 3 08-14-2005 06:07 PM
Starter problems (again!) WakBordr7387 Engine 12 02-03-2005 03:52 PM
starter problems 73chevyhelp Engine 3 05-15-2004 03:49 PM
