84 vette - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2012, 07:07 PM
saltbob's Avatar
Last journal entry: Iembarrassed about starter problem!
84 vette
I'm guessing the person that had the car before me installed the 350 eng.and
the 700R Trans. bolted together so i'm going to remove them together replace
flex plate and some gaskets on both and reinstall them, everything looks a
little tight if anyone has ever done this on '84 corvette and had any peticuler
promblems please let me know i'm planning on doing this Sat 3/10 its ready
to remove now execpt the motor mounts date on picks wrong. Thanks
ID:	63813   Click image for larger version
ID:	63814   Click image for larger version
Old 03-07-2012, 07:22 PM
327NUT's Avatar
I'll just assume you have an engine hoist (obviously) but you need to borrow or rent a tilt cradle that hooks to the hoist chain. This allows you to tilt the engine/trans as you remove it. You will also need to get the front of the car up as high as needed to allow the trans. tailshaft to clear the floor as you tilt. Also tape a plastic baggie (or 2) around the trans. tailshaft so you don't drain nice red messy fluid all over the place....don't rip the bag.
86 vette wayneooo Body - Exterior 1 01-17-2010 06:50 PM
vette a.j.vette Introduce Yourself 2 06-28-2009 09:11 PM
85 vette 85vette Transmission - Rearend 9 05-23-2006 08:31 PM
77 vette help! evilone Body - Exterior 6 10-19-2005 01:57 PM
can I put a bbc in a '68 vette bigwildgrin Suspension - Brakes - Steering 2 04-06-2003 07:48 PM
