-   -   84 vette (http://www.hotrodders.com/forum/84-vette-219709.html)
saltbob 04-09-2012 11:29 AM
84 vette
I've got engine and transmission back in car, my question is the flexplate
is very hard to turn i'm using a crow bar to turn flexplate to get to 3rd bolt
the bell housing to engine is ok, its a new sfi flexplate so does anyone
think its ok finish?
Canzus 04-09-2012 09:33 PM
No, stop now, before something is really knackered, like the thrust bearing or the tranny front pump...
It sounds like the torque converter isn't correctly installed, pull the engine back out, if you have a
beam type torque wrench, put it on the balancer bolt, how much torque is required to turn the engine?
If the tranny is properly installed, you shouldn't need any more torque applied to the balancer bolt to
turn the combination of the engine and trans over...
saltbob 04-10-2012 07:46 PM
84 vette not sure on transmission
Thanks for the help, when I was having problem with flexplate being hard to
turn eariler I did not have trans. level or motor mount on, I now have
everything hooked up and it cranked over just fine. Here's photo showing
between toque contevter and trans. there is no telling whats has been
done to this car before I got it. It looks like a project that was given up on
I don't believe anything is original, a mechanic said he thought i had a 6cl.
it orginally in car I'm tired if its messed up I'll need to go trans. shop :pain:
saltbob 04-23-2012 02:18 PM
84 vette
I put engine and transmission back in vette car will not move any gear
so I have backed off the transmission from bell housing pulled toque
converter off trans. very hard to get torque all the way back in trans.
it has a small section of the shaft that is shinny between torque
converter and trans. does that mean it still needs to go back more and
I have not heard 2 clicks like everyone says, torque converter still turns
but a little harder to turn. Also a vacum line is hooked up modulator
another vacuum with a small canister that I don't know where it goes
somewhere on driver side. :confused: THANk IN ADVANCE!
S10xGN 04-24-2012 08:15 AM
Bob,
IIRC from another thread, you've already had this together and running, right? I'm hoping you didn't force the mounting of the trans-to-block using the bolts. If that was the case, the pump has most likely been trashed. When installing the converter into the trans, there should be 3 distinct "clicks", and with each, there should be some notable rearward movement. For a quick test, you can measure the distance from the block face to the outer edge of the flexplate and subtract that from the distance from the trans mounting face to the converter pads. This should give you 1/8" to 3/16". If the 1st dimension is more that the 2nd, your converter is not seated correctly.
Russ
saltbob 04-24-2012 10:30 AM
84 vette
Thanks Russ I pulled trans. from under car and things are looking better
this is TH350 and all I can get it 2 clicks not 3 I'm not sure this is right
or not I'm going to look back there with mirror, also do you know anyway
to get bolts in bell housing too engine it is very close to firewall 2-3 inches
I can't get my hand to the bolt in some places. Thanks! saltbob
saltbob 04-24-2012 10:40 AM
84 vette
Does anyone know or suggest how to get bolts from bell housing to engine
it's very close to firewall about 2 inches, special tool or anything short of
drilling holes in firewall or pulling engine forward or removal. Thanks!
lmsport 04-24-2012 10:47 AM
I do them from underneath with a long 3/8 extension and a impact swivel and 9/16 shirt socket.
saltbob 05-22-2012 07:15 PM
84 vette
I now have all trans. and starter problems fixad with everyone's help THANKS TO ALL! I think I now have a rear end problem, the vette was sitting on the driveway at home with a slight slope, we were trying to push it inside
garage and the posi-track seemed to lock up. We stopped trying and a few
days later it freed up on its own. The trans. was in neutral and no emergency
brake was on or anything different from the lock up problem a few days later
it rolled right in garage no problem. I had the vette up 1-2 feet up in the
garage on blocks front wheels about 2 ft. up, rear about 1 foot up for 1-2
weeks. The engine was in the car, no trans. no drive shaft in the vette. I had
talked to transmission masters (local shop 2 miles away) When they came to
pick up the vette the posi-track 0n or rear end was locked up again. We checked everything we could think of with no luck, we then hooked up a chain to my PU and pulled it in to the street the guys said it was making thumping sound while
it was being pulled out of the garage and I could hear it when it was being winched on to the trailer so it had something to do with the posi-track or rear
end the wheels were rolling ok we think. A last thought .when I had both rear
wheels on jack stands the garage I could roll the rear wheels by hand to get to
the U-joint bolts. Please advise I am lost as what is going on. saltbob
AutoGear 05-23-2012 07:07 AM
Bob I'd suggest reposting this as a new 'thread' with a more accurate title than '84 vette' perhaps 'rear diff on 84 vette seems to lock up at random'
Then reiterate that the car has a non-factory installed TH350.
Simple dumb question, are the disc brakes on the back locked up
Crosley 05-23-2012 08:51 AM
SaltBOB always titles his threads the same 84 Vette.
I merged them into one thread since he is on the same car, with updates..
Other wise we end up with a dozen threads with same exact title
:pimp:
AutoGear 05-23-2012 08:53 AM
Duly noted.
I'll go back to my hovel LOL
Crosley 05-23-2012 08:54 AM
Duly noted.
oh, I agree with you. SaltBOB needs to expand the thread titles past the "84 Vette"
I suggested this to him weeks ago
saltbob 05-27-2012 11:06 AM
84 vette locking up at random
Thanks what had happened was I had replaced front disc brake's and they had locked up from sitting up for long time with out using I will try to do better with
questions =Crosley]SaltBOB always titles his threads the same 84 Vette.
:pimp:[/QUOTE]
