84 vette shifter suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2012, 05:15 PM
saltbob's Avatar
Last journal entry: Iembarrassed about starter problem!
does anyone have a recommendation for GM 350 transmission floor shift?
been loooking at Summit and Jegs
Thanks
Old 03-22-2012, 09:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I edited the thread title to add information on your question.
Please include additional info so the members have an idea what your thread questions are
Old 03-23-2012, 08:36 AM
What are your goals for this car? If I remember correctly, you ascertained that you had a TH350 thats been retrofitted into your 84 vette? You surely don't need anything with a ratchet mechanism, so really any 3 speed cable operated auto shifter will work. Im not sure, but you may be able to use the factory console shifter as well.
suggestions... on trans and shifter box. PurcyFalcon289 Transmission - Rearend 6 08-14-2010 11:20 AM
shifter tower, shifter rail and shift fork diagram needed! Chris Kemp Transmission - Rearend 0 02-12-2009 06:59 PM
saginaw trans in 76 vette/what shifter to use steve007 Transmission - Rearend 2 03-15-2008 08:02 PM
B&M Auto Shifter in A 86 Vette happydad Transmission - Rearend 1 09-28-2007 05:34 PM
76 vette crate engine suggestions? wildride3434 Engine 5 04-25-2006 08:48 PM
