Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 84 Z28 Rear End TO Posi Traction Conversion
Old 08-07-2006, 07:18 PM
Chazmac Chazmac is offline
Depending on the gear ratio you have, you may be able to purchase a new posi unit. The new ones require a 2.73 or numerically higher gear ratio to fit correctly.
I am a little curious as Z28's had posi carriers from GM...maybe you need new posi clutches and springs...
