84 Z28 Rear End TO Posi Traction Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2006, 07:14 PM
X711
Hi, I have a 84 z28 Camaro with a 5spd trans. I was wondering if it is possible to convert the rear end to posi as its currently non posi or do I have to
completely replace the existing rear end.
Any info is much appreciated.
Thanks ><
Old 08-07-2006, 08:18 PM
Depending on the gear ratio you have, you may be able to purchase a new posi unit. The new ones require a 2.73 or numerically higher gear ratio to fit correctly.
I am a little curious as Z28's had posi carriers from GM...maybe you need new posi clutches and springs...
Old 08-07-2006, 08:51 PM
X711
In 84 I dont believe the Z28 had posi from the factory, but it would be real
nice if I was wrong
I will try access the codes on the rear to see if I can cross reference them to
anything. The rear has 10 bolts, and the tranny is Borg warner.
With the car jacked up if I turn one of the rear wheels anti clockwise
the other wheel goes in the opposite direction.
Thanks ><
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 03:26 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 04:28 AM
82-92 camaro posi rear end info NoEgoMan100 Transmission - Rearend 4 10-21-2005 03:22 PM
Rear End width for V8 S10 s10V8-357 Transmission - Rearend 0 10-08-2003 05:52 PM
What rear end does my 1984 Z28 have? Rubberman2003 Transmission - Rearend 2 10-06-2002 03:55 PM
