'84 Z28 Wheels/Lug Nuts??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2006, 06:38 PM
BT74's Avatar
I picked up a set of 84 Z28 Wheels (15" Alloys), for my '60 Impala recently, and now that I'm going to put them on, I find I need the correct lug nuts. Problem is, according to the Napa catalog, the 84 used a metric lug bolt! I've seen these wheels on a few old cars, was just wondering if anyone here has used them, and how the dealt with this problem? Seem my options are: change the studs to metric (but will the metric shank fit the SAE holes) or find SAE nuts that will work with these wheels. Any info would be appreciated. Thanks.
Old 11-27-2006, 07:20 PM
The Maintenance Geek
Try these guys...
http://www.lugnutking.com/
They helped me put an inch based wheel on a metric car...
K
Old 11-27-2006, 07:24 PM
car builder
Might be cheaper to change the studs.
Old 11-28-2006, 09:56 AM
astroracer's Avatar
Do you know for sure the Camaro rims fit your Impala? I am just asking because the Camaro bolt pattern will be 5 on 4 3/4 while the Impala, being a big car, may have the 5 on 5...
Mark
Old 11-28-2006, 12:33 PM
johnsongrass1's Avatar
Race it, Don't rice it!
IT won't matter a lot the studs are slightly different is size as long as they fit. The taper on the lugnut centers the wheel. Get a lugnut that will fit the threads and make sure the lug taper sit's in the hole.
Old 11-30-2006, 08:16 PM
Mark
Big cars didn't get the 5x5" pattern until '71. '60 is 5x4-3/4".
Make sure the lug nut bevel angle is correct. I think some of the Gen3 Camaro wheels used a different angle from "regular".
Old 12-01-2006, 04:20 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I think the seat (taper) you are looking for is called conical. Contact Summit or Jegs, they should be readily available.
Old 12-01-2006, 04:58 PM
Chopt 48's Avatar
I found the nuts in Dave Wilch's catalog but they arn't acorn nuts.
http://www.marketworks.com/StoreFron...55&i=171917976
I would suggest going to the major custom wheel outlet in your area and checking to see if they have them available.
84 Z28 Rear End TO Posi Traction Conversion x711 Transmission - Rearend 2 08-07-2006 07:51 PM
69 Camaro Z28 & 84 El Camaino trussell28 Introduce Yourself 2 12-31-2005 07:55 PM
84 Z28...what do i need to do to install ford 9"? Rubberman2003 Transmission - Rearend 3 09-24-2003 06:45 AM
84 Z28 power windows Rubberman2003 Electrical 12 06-29-2003 03:39 PM
muncie rock crusher in 84 z28 witchakawicked Transmission - Rearend 0 06-21-2003 04:52 AM
