Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '85 302 decent?? (fuel injection)
Old 12-06-2010, 11:10 AM
matt167 matt167 is offline
Wiki Edits: 31
actually, getting that engine to run a carb is not hard. doesn't even take an intake manifold if you don't mind a 2bbl carb.. just use an electric pump.. but the '84-'85 CFI is probably the worst fuel injection ever. it works, it's just nothing for performance. the cam is small and the heads are terrible... but some E7's ( '87+ HO ) or GT-40/40P's ( '95-'01 Explorer V8 ) will work just fine
