85 305 no spark help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2011, 01:16 PM
hey, I have a 56 dodge with an 85 chevy 305 in it no ecm its carb, a few days ago I burnt out 3 ignition control modules in one day. until not even replacing the icm would start it. ive replaced the whole dist. with an accel one. new pick up coil new capacitor new coil new wires new icm new rotor and cap the coil is grounded properly and so is the engine. but I checked the wires to see if the plugs were getting spark with a tester and nothing no spark. any suggestions.
Old 01-29-2011, 02:38 PM
LATECH's Avatar
Last journal entry: New Gas Tank
post the distributor/ignition system/components you are using now, not much to go on here.
Also have you verified 12 volts source and the proper connections. I suspect there is either no voltage and/or you dont have the new system wired properly.
Old 01-29-2011, 05:33 PM
EOD Guy's Avatar
I once burned out 2 coils before I realized I had mistakenly cut the resiator wire from the system, I ended up putting a resistor from a chrysler in line with the +12v and all was fine
Old 02-02-2011, 03:29 PM
I have a standard hei coil in cap ignition system. semi new wiring done a few yrs ago. I jumped the bat term to the coil and now have spark to the wires but still wont get the car to start. I have fuel getting to the carb dont know where else to look
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 05:14 AM
No Spark!!!!!! Mr AMC Electrical 8 03-22-2009 05:15 PM
blazer has spark at coil and gas no spark at plugs ricksautorestoration Engine 29 02-15-2007 08:30 AM
spark plug getting little spark 72 chevy elcamino Electrical 1 10-19-2003 04:54 PM
spark plug spark rustyrazer Hotrodders' Lounge 1 12-24-2002 03:57 AM
