'85 700r4 work in a 1990 k1500 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-09-2008, 11:30 AM
700r4
Do you mean it makes a 1-3 upshift? Does it make a 3-4 upshift?
See I wonder if when you swapped all that stuff around, vb, checkballs etc, did something not get put back right.
You started off with a no upshift, maybe it was because of the TV valve sticking, maybe not.
Then you swapped all that stuff around.
Did you ever answer Crosley when he asked about the 87 unit, rebuilt, used?
If the unit was rebuilt, I would asks the person that rebuilt it what he thought.
If the unit was used and the pan was clean when you swapped that stuff around then I would buy the trans go kit and put all of the original stuff back in.
I know I have said this a bunch of times on this forum but.... a no upshift on a 700R4 needs to have a gauge on it. You check the cable then a gauge goes on it.
If you have pressure over 100psi then the TV valve is sticking.
will 4l60e work in my 89 silverado? It has a 700r4. mojokimble Transmission - Rearend 2 04-21-2006 08:16 PM
Front clips and frame swaps --- More work, less value Centerline Suspension - Brakes - Steering 23 05-25-2005 08:42 PM
700R4 Made to work? Larry Day Transmission - Rearend 2 11-23-2003 12:26 AM
1990 700r4 Captin21 Transmission - Rearend 1 10-11-2003 01:22 AM
700R4 vs. 2004R 81ElCaminoGuy Transmission - Rearend 2 08-21-2002 01:10 AM
