Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '85 700r4 work in a 1990 k1500
Old 01-07-2008, 03:34 PM
briscoe briscoe is offline
85 700r4
The aux vb is that alum thing that is at the rear of the trans, right behind the main vb, the one that has the tube coming from the pump that goes into it. Forward clutch feed.
As Crosley pointed out, swapping vb and other parts can get you into trouble.
I would put the original stuff back on this trans. Along with the correct harness and switch.
As per your trans not upshifting, sticky TV valves are a huge problem for the 7ooR4.
For about $30.00 you can buy the Trans Go jr shift kit, which comes with a TV valve that will not stick.
Easy to install, has good directions as well.
Every 700R4 we build at my shop has this kit installed.
