#1
85 camaro 700r4 to th350
I have a 1985 camaro Z28. I'm dropping a 383 in it and was told my 700r4 isn't "good enough". I'm wanting to put a th350 in it the easiest/cheapest way i can but still make it sturdy. Is there some kind of spacer i can ad to a th350 (3 or so inches) so i dont have to get a shortened driveshaft? Or can i change the output shaft and whatnot on my 700r4 and put it on my th350? thanks, drew
Register now (free) or login to remove ads |
#2
on what you`ll spend to add the TH350, I would just get the 700 rebuilt with upgraded parts. the 700 has a lower first gear for better hole shots and the overdrive for a much pleasant cruise without the annoying high RPM exhaust drone that will drive you nuts. you`ll have to get a painless wiring kit or the like to keep the lock up function. I`m sure you could look in the knowledge base on this site and find more info, or someone else here will tell you what upgrades the 700 would need.
#3
If you are going to be making enough power to hurt a 700R4, then you might as well just go to the TH400. I have a kit for the TH400 that allows a direct bolt in swap. It does exactly what you are talking about, correcting the length and mounting location.
Email me if you need details. |
#4
I agree, beef up the 700 and have the best of both worlds. In top form it can pretty much handle as much as a 350 and get better mileage, and quicker launches with it's overdrive and lower, low gear ratio. The sunshell and 3-4 clutch seem to be the weakest links in the trans, but there is upgrades for them as well as the gears.(planets)
If you must have a 350, choose one from an late 70's early 80's truck, depending on whether or not you want L/U. They have the 9 inch ext. hsg. and output shaft that you need to re-use your original drive shaft. You will have to relocate your crossmember though. |
#5
You will also need the kit to relocate the torque arm mount at the tranny if you go the T-350 or 400 tranny.
That is the arm that runs along side the drive shaft from the rearend. I would have the 700 built correctly and drive the car. __________________ I gotta sign this too? Tony
At the Bonneville Salt Flats, first gear is known as 130 mph. |
#6
ya I second that keep the 700 they can be built very strong and you will be happier with it than the 350, not that there is anything wrong with a turbo 350 but going to it would be a big step backwards.
