85 camaro rear end problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2008, 07:03 PM
i have an 85 camaro used to have v6 now runing a 350. stock rear end non posi. speedo is off bout 15mph. i get a howl at speeds over 70 and some smoke but only when under power not when u coast. help me
Old 09-20-2008, 07:16 PM
Jmark's Avatar
Welcome to the HR forums!
I'll move this to the trans/rear end forum for, hopefully, lots of suggestions.
Mark
Old 09-20-2008, 07:41 PM
SSedan64's Avatar
Sounds like your 350 has smoked your weak 7.5" rear.
Old 09-20-2008, 10:10 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
It has probably wasted the bearings in the rearend, but that wouldn't cause smoke.
The smoke is probably an oil leak, or its burning oil that is leaking past the valve seals or rings.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
85 Regal rear end dilema Regal Beagle Transmission - Rearend 5 04-19-2008 06:11 AM
67 camaro rear end question shclayto Transmission - Rearend 6 10-11-2005 09:24 PM
96 camaro rear end fit in 84 regal 225buick Transmission - Rearend 5 04-18-2003 04:10 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
