85 Chev 4x4, rearend replacement options - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2002, 05:02 PM
Post 85 Chev 4x4, rearend replacement options
The rearend in my son's 85 chevy C10 4x4 p/u failed. Since the 8.5", 10 bolt rearend had a 4:10 ratio (which from what we've been told is not stock) we would like to know, 1.If we can use a 4x2 rearend to build a new one. 2.would the carrier size be the same regardless of the ratio and 3.Is the axle diameter and splines the same for a 6 lug -vs- 5 lug.
Any help would be greatly appreciated.
