85 chevy c10 reverse lights dont work - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2011, 05:12 PM
I have an 85 c10 that the reverse lights dont work. I checked the lights and they are good. I dont have a haynes manual so i cant look it up. I have a th350 so i dont have a semi conductor on the tranny. anyone know what i should do. i dont think that the lights are getting the signal from whatever sensor the reverse lights use. and i dont know where it is located either.
Old 04-14-2011, 05:57 PM
T-bucket23's Avatar
Wiki Edits: 26
85 is probably part of the NSS switch at teh bottom of the column
Chet
Old 04-15-2011, 12:34 AM
Info I have is the back up light switch is on the column in the NSS on automatic trans. trucks, on the column on 3 speed manuals, (didn't know they made a 3 speed manual) and in the transmission on 4 speed manuals.
Old 04-17-2011, 12:55 PM
Neutral Safety switch
ok so i check my nss by putting it in drive and trying to start it. The nss worked like it should, it didnt let me turn the key and start it. So why are my back up lights still not working.
Old 04-17-2011, 02:40 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The back-up light switch is part of the NSS.
There should be 4 wires connected to the switch. (2) wires are for NSS and (2) wires are for the back-up lights.
The switch is located on the lower part of the steering column.
Also check for a blown fuse and for a bad ground at the lights.
To test the switch remove the blue and lt green wires and install a jumper between the wires. Turn on the ignition. The headlights may need to be on. If the lights light, the switch is bad or not adjusted correctly.
vicrod
Old 04-17-2011, 04:19 PM
back up lights
THanks I will take a look at that. if it needs to just be adjusted. how do you do that?
Old 04-17-2011, 08:12 PM
1984 C-10 383 SBC
The part is white plastic, has notch's or detent's on it. You move the part on the switch by hand, either right or left checking for backup light's after each click. This is not hard at all too do. Hope this help's another C-10 owner.
Old 04-18-2011, 12:18 PM
Nss
So I checked the Lt. Green and Purple wire on the NSS, and they were plugged in backwards. I switched them and tada back up lights.
Old 04-18-2011, 04:57 PM
vicrod's Avatar
life is a ride
If the car starts your good.
Glad it worked out for you.
vicrod
signal lights dont work.... sexypizzaman Electrical 14 12-02-2008 08:44 PM
reverse lights ideas for '65 chevy c10 lwb stepside? Woogeroo Electrical 6 04-06-2006 08:33 AM
ideas for reverse lights - '65 chevy truck Woogeroo Electrical 2 12-08-2005 06:48 PM
79 Chevy Reverse lights hiball Electrical 6 12-28-2004 10:20 PM
brake lights dont turn on grover805 Electrical 3 10-10-2002 12:40 PM
