85 chevy pickup qustion - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2006, 03:32 PM
Im doing some work on my neighbors 85 Chevy 3/4 ton pickup that he just bought from the fire department. It has really lo gears in it something like 4:56's if that sounds right. and i was wondering is i could put the front and rear end carriers from a 74 1/2 ton pickup in it. Thanks in advance
Old 11-28-2006, 10:04 PM
rear end issues
the carriers from the 1/2 ton wont fit.... the rear is probably a 8.875(12 bolt)from the 74,the 85 should have a 9.5"(smallblock) or 10.5"(big block)the front axle from the 74 is going to be a dana 44,the 85 should be a 8.5" sorry...
Old 11-29-2006, 09:11 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
If you want to swap out the entire axle housing wheel to wheel on both the front and rear of the truck it will work just fine.
Pete was right on the carriers though, won't work.
Old 11-29-2006, 10:53 PM
thanks for the info il see if i can get it to work
Old 12-02-2006, 08:49 PM
fast68's Avatar
likes chevy trucks & boobies
wow you are wanting to do the complete opposite that everyone else does with these trucks, i think youre the first perso ive ever heard of wanting to downgrade/lighten a k20 or k30
i bet its a real nice and well maintained truck, sorry to hear its going to be modified, i was wanting to get this really sharp 79 k30 that the local fire dept auctioned off recently,
i think it only went for 1500,
it was crazy
anyways, the carriers wont swap,
the axles under both the trucks are different models/size,
the 74 would be a 12 bolt 8.875 rear and dana 44 front
and the 85 would be either the 9.5 or the 10.5 14 bolt rear and a 10 bolt 8.5 front as previously said
you would have to swap entire axles out, and that will require driveline/u joint work and using the 1/2 ton u bolts and plates and so forth
good luck
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Front end for a 47-54 chevy Pickup olsen2544 Suspension - Brakes - Steering 8 08-01-2005 08:46 AM
Chevy 350 Engine & Trans in a 46 Chevy Pickup Warner Engine 4 02-11-2005 04:44 PM
Headlights for my 54 Chevy Pickup horvath Electrical 11 01-10-2005 07:15 AM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
