Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 85 chevy tps test results
Old 07-09-2012, 12:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 85impala View Post
Hey guys, I have a 85 chevy Impala with a 305 and cc-qjet I recently did the throttle position test and with the car off but ignition on, the tps is reading .17 volts with the throttle closed. When I knock the throttle linkage wide open for a sec it goes to around .90 but I didn't see it pass .9. When I knock the throttle open its just for a second because I don't want it flooding so please tell me if I'm doing it wrong. I also made sure the tps was receiving the 5v from the computer
Is this a good reading? If not can I adjust it?
If the engine is off, there will not be any fuel flow other than the accelerator pump shot. So unless you are opening/closing/opening/closing the throttle repeatedly, there's no way to flood it.
IIRC the voltage should be around 0.5 v at idle. Hopefully LATECH will see this and lend a hand. I wonder if this should go in the Modern Electronic Engines forum...
