Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 85 chevy tps test results
Old 07-11-2012, 01:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 85impala View Post
Well after searching online for awhile I found the 2.5mm hex socket I need for the tps screw on the air horn.
The cheapest I found Thexton #362 was 32$ shipped from advance auto parts.
Does anyone know of a cheaper tool or adjustment method I could use?
32$ for turning a single screw is a little much
You sure it's not a torx bit you need- ike a T25?
If it's like an allen head, use something like a 2.5 mm hex drive socket for $10 if you don't have a metric allen wrench set that goes that small. Or buy a metric allen wrench set that includes a 2.5mm and add it to your tool box.
Or hit up the local AutoZone (or whatever you have) and pick up a tool there like OEM brand carburetor adjusting tool p/n 25062, about half the cost you saw earlier.
The Following User Says Thank You to cobalt327 For This Useful Post:
85impala (07-11-2012)
