Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 85 chevy tps test results
Old 07-11-2012, 04:21 PM
85impala 85impala is offline
Originally Posted by cobalt327 View Post
You sure it's not a torx bit you need- ike a T25?
If it's like an allen head, use something like a 2.5 mm hex drive socket for $10 if you don't have a metric allen wrench set that goes that small. Or buy a metric allen wrench set that includes a 2.5mm and add it to your tool box.
Or hit up the local AutoZone (or whatever you have) and pick up a tool there like OEM brand carburetor adjusting tool p/n 25062, about half the cost you saw earlier.
I really can't see the head of the screw, Thexton #362 says Fits Varajet, Dualjet and Quadrajet carbs with 2mm, 7mm, 10mm Double-D and 2.5mm hex fittings For 7/16 and 1/2 sockets
I do have an autozone by me so if 2.5mm is the correct size I will definitely get the one you posted
I appreciate all the help
