-   Modern Electronic Engines (http://www.hotrodders.com/forum/modern-electronic-engines/)
-   -   85 chevy tps test results (http://www.hotrodders.com/forum/85-chevy-tps-test-results-221470.html)
85impala 07-09-2012 11:24 AM
Hey guys, I have a 85 chevy Impala with a 305 and cc-qjet I recently did the throttle position test and with the car off but ignition on, the tps is reading .17 volts with the throttle closed. When I knock the throttle linkage wide open for a sec it goes to around .90 but I didn't see it pass .9. When I knock the throttle open its just for a second because I don't want it flooding so please tell me if I'm doing it wrong. I also made sure the tps was receiving the 5v from the computer
Is this a good reading? If not can I adjust it?
cobalt327 07-09-2012 12:23 PM
If the engine is off, there will not be any fuel flow other than the accelerator pump shot. So unless you are opening/closing/opening/closing the throttle repeatedly, there's no way to flood it.
IIRC the voltage should be around 0.5 v at idle. Hopefully LATECH will see this and lend a hand.:cool: I wonder if this should go in the Modern Electronic Engines forum...
85impala 07-09-2012 12:44 PM
Cool I was pretty worried about flooding it thanks for clearing that up for me.
.5v sounds about right, I think I read that somewhere but I'll wait for a confirmation.
85impala 07-09-2012 02:30 PM
So I went to re-test the tps and held it wide open and got 1.03 volts.
I was also wondering what happens when the tps has too low or too high of a reading
LATECH 07-09-2012 05:31 PM
the voltage should be at .58 volts, with the throttle plates closed at curb idle, not on the fast idle cam or with the idle speed controller ram pushing the throttle open.
When you open the throttle wide open the value should be at 4.90 volts .
1.0 volts at wide open throttle is too low, not sure what is going on there.
Without enough throttle posisition sensor voltage , hitting wide open throttle will be somewhat lean, and shy on timing as RPM s build.
Also it may set a check engine light,as value may constantly be to low for engine rpms.
85impala 07-09-2012 05:49 PM
Thanks for your reply LATECH.:thumbup:
It sounds like its wayyy off according to your statement, should I adjust it at the hole by the accelerator pump lever (I think that's what it's called )? Or should I install a replacement?
I actually have a few extra dualjet and quadrajet tps's I could pop in there so I wouldn't have a problem replacing it.
Thanks again
LATECH 07-09-2012 07:06 PM
Yes. The little cap on the boss where the accel pump lever goes has the adjuster underneath.
Those can be tough to get out.I have drilled CAREFULLY and used a blunt ended screw to screw into it to pull that cap out. Watch out because the cap is thin and if you drill too much, you will damage the top of the adjuster screw and you wont be able to turn it.
If you have another clunker carb, practice on that one first.
If the adjuster screw was screwed in too far clockwise (normal-righty tighty) then the TPS would read low. Tuning the adjuster clockwise pushes the TPS housing down in its bore, which allows the plunger to extend, which lowers the voltage at the output terminal.
85impala 07-09-2012 10:58 PM
Thanks for all the help, I understand it perfectly now :D
:thumbup:
85impala 07-10-2012 12:27 PM
I went to look for the cap on the airhorn, and it was gone.
There is a tiny hex looking screw in there, its pretty deep and none of my tools will work.
Is there a special tool I need? I tried needle nose pliers but they can't even reach the screw:mad:
85impala 07-11-2012 12:25 PM
Well after searching online for awhile I found the 2.5mm hex socket I need for the tps screw on the air horn.
The cheapest I found Thexton #362 was 32$ shipped from advance auto parts.
Does anyone know of a cheaper tool or adjustment method I could use?
32$ for turning a single screw is a little much
cobalt327 07-11-2012 01:31 PM
You sure it's not a torx bit you need- ike a T25?
If it's like an allen head, use something like a 2.5 mm hex drive socket for $10 if you don't have a metric allen wrench set that goes that small. Or buy a metric allen wrench set that includes a 2.5mm and add it to your tool box.
Or hit up the local AutoZone (or whatever you have) and pick up a tool there like OEM brand carburetor adjusting tool p/n 25062, about half the cost you saw earlier.
85impala 07-11-2012 03:21 PM
I really can't see the head of the screw, Thexton #362 says Fits Varajet, Dualjet and Quadrajet carbs with 2mm, 7mm, 10mm Double-D and 2.5mm hex fittings For 7/16 and 1/2 sockets
I do have an autozone by me so if 2.5mm is the correct size I will definitely get the one you posted:D
I appreciate all the help:thumbup:
