85 chevy truck holley carb issue
i have a 85 chevy truck with a 1979 350sb in it .it is a stock engine i have a holley 600 cfm carb on it which i had rebuilt less than 2 months ago. it ran rich even when i adjusted it correctly. it had 64 main jets in it . i dropped the jet size down to 60 and now it has a slight surge at low speeds (around 30 mph or so) is this too lean for this motor ..what size jets should i use to eliminate this problem
try raising the float lever slightly or 61/62 jets
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
chevyman72 (02-13-2013) | ||
i'll order up the jets tomrow just in case.the float is adjusted to u can just see the fuel at the bottom of the sight hole
| The Following User Says Thank You to kleen56 For This Useful Post: | ||
i kinda figured it was too lean kleen..i just ordered #62 jets from summit i should have them by saturday...ill give a whirl again when i get them
How is the timing set up on this engine- how much initial and total, w/o adding in the vacuum advance? And is the vacuum advance being used and if so is it connected to manifold or ported vacuum? It should run better using manifold vacuum... |
Here is the manual for the Holley 600 carbs. According to the manual the carb came with 65 jets in the primary and secondary. http://www.holley.com/data/Products/...7948-5rev5.pdf. Check your vacuum the engine makes at idle. If 12 or over use a 65 power valve.
i'm not too sure on the timing..i dont belive there is a vacum leak i had replaced all the vacum lines..i'm picking up a vacum guage in about an hour i belive the proper vacum for this engine should be between 19-21hg i have a set of #62 jets comming from summit tommrow.hopefully something gives..its getting frustrating
| Holley 950HP Carb issue that I have never seen before...input? | oldschool101 | Engine | 7 | 04-16-2012 10:37 PM |
| 98 chevy truck transmission issue | chevymartin | Transmission - Rearend | 1 | 12-26-2011 05:27 PM |
| AED (holley) carb issue | dawg | Engine | 8 | 07-04-2008 09:41 AM |
| Edelbrock or Holley Carb. for my street/strip Truck | anthony4401970 | Engine | 12 | 02-26-2008 12:03 PM |
| Holley Carb Issue here. | my350camaro84 | Engine | 11 | 01-03-2005 06:54 PM |
