85 Corvette TPI with Q Jet? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2010, 11:49 PM
Thinking of installing 85 350 TPI into 84 truck with 305. The 350 doesn't have the TPI. Will it run good with my Q Jet and intake? Also could use Performer intake and Edelbrock 650. Thanks for helping.
Old 07-15-2010, 06:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Emissions regulations and smog checks aside, the 350 TPI engine will run fine w/an intake and carb.
If you're positive the engine is a 1985, the intake center bolt holes are the same as the earlier carbed engines, so use an intake designed to fit them, NOT an intake made for the revised center bolt hole angles of the '87-up heads used on the Camaro, for example.
Old 07-15-2010, 08:11 AM
DoubleVision's Avatar
Don`t use the TPI`s HEI, it has no mechanical or vacuum advance, it`s advance is controlled by the computer so you`ll need a older HEI.
Old 07-15-2010, 05:38 PM
Thanks for the help. Would you use the Q Jet and Performer over the Edelbrock 650 or stock 350 manifold?
Old 07-15-2010, 08:08 PM
I would use a Quadrajet and the performer. For a street carb you can`t beat a Quadrajet.
Old 07-17-2010, 02:13 AM
I'm considering having the heads done and not rebuilding anything else. Is that usually not a good idea?
Mel
Old 07-19-2010, 09:36 PM
I see mid 90's GM Vortec heads are available for about $650. Looks like they are 64cc instead of 76cc. How much would that change my compression and what horsepower gain is likely?
Old 07-19-2010, 10:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It will raise the CR by about 1.25:1 on a 0.030" over 350 SBC, w/zero deck, 0.041" x 4.1" dia. gasket and 5cc valve relief FT pistons. The exact chamber and valve relief or dish volume will need to be measured to be more precise.
The power gain has been said to be 25-50 HP.
1984 corvette crossfire injection change to 1985 TPI injection billybonesmusic Engine 9 06-08-2006 07:21 AM
tpi system on a non tpi setup Siggy_Freud Engine 2 02-18-2005 10:05 PM
TPI timing Siggy_Freud Engine 2 04-14-2004 11:28 PM
88 Corvette tpi with Turbo400? wayja Transmission - Rearend 2 05-25-2003 08:37 AM
88 Corvette TPI with Turbo 400? wayja Engine 1 04-11-2003 04:13 PM
