Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 85 impala timing
Old 09-17-2012, 05:00 PM
85impala 85impala is offline
Originally Posted by LATECH View Post
Sounds typical for a car with no exhaust system, however the tube on the passenger side that you said " sucks" needs to be plugged. It is allowing air to be pulsed into the exhaust stream...most likely causing the issue.
Cool I'll do that, thanks for the help
