85 impala timing - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 09-16-2012, 04:41 PM
85 impala timing
hey guys, i have a 85 impala with a 305, quadrajet, and its all computer controlled with esc
well i noticed my timing is off because i hear slight pops through the exhaust and it goes away when i jump pins A and B to stop the computer advance.
i bought an aftermarket timing pointer, found TDC and marked it on the new pointer. On the timing tape it shows 0* when the A and B terminals are jumped. and shows 20* when running normally at idle.
my questions are
1) is it normal for the computer to be advancing that much at idle?
2) where do i go from here?
Im very new at this, just bought the car this year so please bear with me
Let me kno if you guys need more info
thanks,
clint
Old 09-16-2012, 06:06 PM
LATECH's Avatar
20 is pretty normal .
Not to sure timing would be the issue here. Did the symptom occur after a timing adjustment? Did anyone adjust the timing?
Sounds like air getting into the exhaust stream. Maybe the EGR valve is sticking?
Could be also the carb is too rich. Also faulty AIR check valves can let air into the exhaust when not wanted and cause a pop or a burble.
Fact is stranger than Fiction
Old 09-16-2012, 06:58 PM
Well when I bought the car my buddy set the timing because it was running really rough. I didn't have a timing light so it was set by ear, and he put a chrome cover on of course.
I just noticed it now a few months after the timing was set, it sounds like a quiet pop or thump. No repetition or anything. I could only hear it when I'm by the exhaust and it kinda shakes the car. And I see a spike in the a/f when it happens, maby 16.0 max
I'm not sure what the AIR check valves are but I'll research it.
Theres a tube from my cat that comes up on the pass. side and it sucks, I'm not sure what that is.
We also replaced the huge stock air cleaner with a chrome one and removed the AIR tubes from the manifold
I have an a/f ratio gauge that's reading 14-15 so its not too rich
I'll check the egr valve, I didn't think of that.
Thanks for the reply
Old 09-17-2012, 11:46 AM
Here is a video that will probably describe the noise better than words,
It was taken on a cell phone so its crappy quality.
https://www.youtube.com/watch?v=KPeL...e_gdata_player">https://www.youtube.com/watch?v=KPeL...e_gdata_player" type="application/x-shockwave-flash" width="425" height="350">
I'll check the EGR valve and if I could find the AIR check valves I'll check that too later on today.
Thanks for the help
Any comments or ideas are greatly appreciated
Old 09-17-2012, 11:52 AM
Fail
Exhaust popping - YouTube
"> Exhaust popping - YouTube
Old 09-17-2012, 04:18 PM
LATECH's Avatar
Sounds typical for a car with no exhaust system, however the tube on the passenger side that you said " sucks" needs to be plugged. It is allowing air to be pulsed into the exhaust stream...most likely causing the issue.
The Following User Says Thank You to LATECH For This Useful Post:
85impala (09-17-2012)
Old 09-17-2012, 05:00 PM
Cool I'll do that, thanks for the help
Old 09-17-2012, 06:32 PM
That definitely worked, if I could hit the "thanks" button twice I would
Old 09-17-2012, 06:43 PM
LATECH's Avatar
Excellent, glad to help
Old 10-14-2012, 07:05 AM
EagleMark's Avatar
GearHead-EFI.com
You can't set timing by ear.... these CCC and all GM EFI systems are usually set to 0 advance with Bypass wire disconnected, usually a tan wire with plug from the EST-ICM modle in distributor. ESC is module for knock system retard, Disconnect this wire and set timing to 0 with light. Then when plugged back in ECM will control timing and can be 10 to 20 degrees advanced. Will also set a DTC so disconnect battery to clear codes.
The Following User Says Thank You to EagleMark For This Useful Post:
85impala (10-14-2012)
Old 10-14-2012, 11:25 AM
Cool, that clears things up a bit.
Thanks
Old 11-18-2012, 09:25 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
yea you have to disconnect the by pass wire, One the b bodies its over near the passenger hood hinge area, and I hope the timing pointer was in the same place as the old cover, I know alot of those 80's SBC's had the pointer under the W/P at 12o'colck, using a aftermarket on with the side and not swapping the harmonic balancer with have the timing marks WAY OFF.
Old 11-18-2012, 12:16 PM
Yea my factory timing pointer was around 12 o'clock right behind the water pump, but since my buddy got me a chrome timing cover without a pointer I had to buy a new 2 o'clock pointer which really screwed things up, so I found TDC again and made a new slit on the balancer inline with the new pointer
Recent Modern Electronic Engines posts with photos
What is 1972 Impala 350/2bbl ignition timing ? custom_rider Hotrodding Basics 2 11-24-2011 10:37 AM
65 impala 327 timing kizer Engine 2 11-22-2007 10:21 AM
WANT TO TRADE? LHD 64' Impala dash for RHD 64' Impala Dash garagedoreen Interior 1 11-18-2007 07:55 AM
Switching 63 Impala to 64 Impala heat control dmaggard Interior 2 09-13-2006 07:17 PM
1965 Impala 327 Timing Question EazyDuzIt102 Engine 2 06-25-2004 03:07 AM
