85 merc won't shift to high gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2011, 09:41 PM
I have an 88 mercury marque with 4sp auto transmission. runs fine but only shifts thru 1st and 2nd gears, does not shift to high. trying to determine if this is going to cast a bundel to fix or whether Im better off getting a used one from a wrecking yard.
36int
Old 01-08-2011, 10:30 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
36int
3rd gear is a known problem in the AOD trans.
Mileage on this trans?
Have you checked the TV linkage at the engine and trans for proper operation? Often the connector wears out - breaks and the TV link comes loose, this will cause many problems and damage the trans
c4 will not shift into 3rd gear royhldn Transmission - Rearend 4 10-20-2009 11:01 PM
th700r4 (1984) shift only high rpm Chris34 Transmission - Rearend 7 09-08-2009 02:41 PM
late-no high gear shift th400 54chevrat Transmission - Rearend 5 02-20-2007 04:34 PM
More Info, High RPM to Shift on 700R4 Ted Bundy Transmission - Rearend 3 11-25-2003 06:44 PM
AOD won't shift out of first gear rvesterby1 Transmission - Rearend 7 03-16-2003 12:13 PM
