Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 85 monte carlo brake problem.
Old 12-22-2009, 01:00 PM
cobalt327's Avatar
cobalt327 cobalt327 is online now
WFO
Wiki Edits: 1616
Originally Posted by 406 ss monte
the only time they lock up now is when the car has sit overnight , then when we go down the driveway the rear will lock up in the gravel. after you drive it, it's good for the rest of the day. what the hell?
So, say you go through the ritual and now the brakes are working 'right'. What happens if you do the driveway again? Will the rear brakes then NOT lock up in the gravel?
I ask, because I'd almost expect the rears to lock up before the fronts- on gravel at least- because of the lack of traction in general and the front weight transfer.
I'm wondering whether you have too much rear bias or not enough front?
If there seems to you to be a lack of front brake, the calipers might have stiff pistons that allow the rears to "out brake" the fronts. Or, like you said, the MC could be the problem. If it's original, I'd expect it to be tired.
