85 monte carlo stock rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2008, 10:58 AM
85-monte's Avatar
Last journal entry: 1985 Monte carlo LS
I was wondering if any body could tell me how to identify or just knows what the stock rear end in an 85 Monte Carlo LS. Is it A 2 or A 3 series?
Thanks,
Logan
Old 02-15-2008, 02:31 PM
leldai73's Avatar
Its just metal,you're the boss
i have no idea what you mean by 2 or 3 series, but more than likely its a 7.5 inch ten bolt. fairly easy to identify. also a weak point.
http://www.maliburacing.com/rearend/GM10-Bolt-75.jpg
check out www.maliburacing.com 's tech area for lots of good info.
Old 02-15-2008, 02:38 PM
It is a type of gear set. As i believe the different series you have, there is a certain gear ratio you can use for that particular series. For example on a 12 bolt with positration the series/gear combo would be:
series 2 = up to 2.90; 3 = 3.08-3.90; and 4 = 4.11 up or to that effect.
This isn't true for a 10 bolt but if it helps any, on my 87 MCSS i have a 2 series with 3.42's on it.
Old 02-18-2008, 02:32 PM
MI2600's Avatar
Member# 3287
My '86 El Camino with a 305 and TH200 trans came with a 2.41 rear.
Old 02-19-2008, 08:42 PM
my 82 olds came with 2.14's and and a 3.8 buick v6 needless to say that all ended up in the dumpster real quick
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 03:25 PM
Question about a monte carlo rear end... Mike_82 Transmission - Rearend 3 10-29-2003 10:38 PM
83-88 Monte SS Rear end tsorens Transmission - Rearend 5 01-26-2003 04:21 PM
Rear end Buffed Engine 3 10-31-2002 06:11 AM
How can i juice up my 305 in my 85 monte carlo? john 85 Engine 4 07-24-2002 11:30 PM
