85 Olds to Chev fan shroud problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2006, 08:23 PM
Redman Racing
After I installed the chevy 350 inplace of the 307 olds in my 85 Cutlass I have ran into a problem. The original fan shroud does not even come close. I was wondering if anybody had experience with this. I have a friend with a fan shroud from a 88 monte 305-could that work?
Some one give me a clue???
Old 03-25-2006, 09:04 PM
DoubleVision's Avatar
When I did this same swap, I reused the same shroud. When I looked at a carlo`s shroud it didn`t appear to be any different. as long as you used the factory motor mount location there shouldn`t be any problem with yours. give more detail on how yours is falling short.
Old 03-25-2006, 09:58 PM
Redman Racing
the only thing I can come up with is that I have Moroso solid motor mounts and a long style edelbrock victor water pump with a stock 305 cluch fan. I have no clue what I was thinking at the time but I throught it against the rad support and it hit the fan and i tossed it. There for I am stuck without a fan shroud to even determin if it would fit now.
as long as you used the factory motor mount location??? How did you do that with a olds to chevy motor. They mount farther to the front of the car and with the moroso one of the tabs hangs past the crossmember. maybe I am just reading you wrong or I am to tired...
Old 03-26-2006, 07:24 AM
What I was saying was the small block chevy mounts have there own holes already pre drilled in the frame, They drilled the frame for all the engines that came in the G body line since the frame is built first. All the V8`s that came in these cars used the same crossmember so the only difference was were the different engines mounts were located. The fan on both the olds and the chevy engines sit close to the same place, the difference is the height, my fan was too close to the shroud at the top so I used a smaller diameter fan of around 17 inches. I`ve seen some guys do this same swap and drill new holes, and I could never understand why since the holes are already there for the motor mounts. If the front of the mount is hanging over in the front then you hit the right ones.
Old 03-26-2006, 08:45 AM
Redman Racing
"maybe I am just reading you wrong or I am to tired..." yep
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
cooling fan problem Johnny Bravo Electrical 1 07-11-2003 03:12 AM
EZ-Wire : Fan Connection horvath Electrical 11 03-28-2003 10:35 AM
please help..... annoying warm start problem 67cuda Engine 21 03-28-2003 05:44 AM
403 olds in 85 toyota celica toymobile Engine 5 01-01-2003 04:05 PM
