85 Regal rear end dilema - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2008, 08:41 AM
Regal Beagle's Avatar
Here's the deal. I have an 85 Regal with SBC 355 putting out 385 HP and 420 lb/ft TQ........in the car now is a 7.5" 3.42 rear end with posi........freshly rebuilt.......I have the opportunity to pick up a brand new Currie 9 inch, 31 spline Moser Axles, 3.50 with Tru-Trac for $ 1300 installed.
What would you do?
Old 04-18-2008, 08:48 AM
If it is a ready to be installed ( built for the Regal ) 9 inch ... I would be laying the $$$ in the guys hands NOW. End of story.
That's a LOT of goodies for the money.
Old 04-18-2008, 08:52 AM
It is a direct bolt on for the G-Body.
Old 04-18-2008, 09:05 AM
With only 385HP/420TQ ... you will never hurt the 9 inch
The 9 inch also gives you the easy way to change rear end gears ... if you want to get serious and go to the track. The 9 inch also has better axle bearings ...
The only downside is that the 9 inch has a higher parasitic drag factor ... ( has a slightly higher loss of power to the rear wheels ... due to friction and engineering factors )
Old 04-18-2008, 09:21 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Such a deal..if I found one of those ready to bolt in my rig it would be going in there..End of story..
Sam
Old 04-19-2008, 06:11 AM
You ever use slicks and hook it up you will be buying a rearend any way so buy it now.
speedo and rear end question hddave1 Transmission - Rearend 12 04-22-2008 07:31 AM
need basic rear end info. oldguy829 Transmission - Rearend 6 04-16-2008 03:28 PM
68 Camaro Rear end Curtis Thornton Transmission - Rearend 14 03-12-2008 05:19 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Chevy rear end swap Truplayainfla Introduce Yourself 1 10-23-2004 11:07 PM
