If I am correct in my thinking the connector is for test purposes but I have attached a wiring diagram for an '85 2.5
Kevin
Chassis Electrical UNDERSTANDING AND TROUBLESHOOTING ELECTRICAL SYSTEMS
Troubleshooting
When diagnosing a specific problem, organized troubleshooting is a must. The complexity of a modern automobile demands that you approach any problem in a logical, organized manner. There are certain troubleshooting techniques that are standard:
Establish when the problem occurs. Does the problem appear only under certain conditions? Were there any noises, odors, or other unusual symptoms?
Isolate the problem area. To do this, make some simple tests and observations; then eliminate the systems that are working properly. Check for obvious problems such as broken wires, dirty connections or split/disconnected vacuum hoses. Always check the obvious before assuming something complicated is the cause.
Test for problems systematically to determine the cause once the problem area is isolated. Are all the components functioning properly? Is there power going to electrical switches and motors? Is there vacuum at vacuum switches and/or actuators? Is there a mechanical problem such as bent linkage or loose mounting screws? Performing careful, systematic checks will often turn up most causes on the first inspection without wasting time checking components that have little or no relationship to the problem.
Test all repairs after the work is done to make sure that the problem is fixed. Some causes can be traced to more than one component, so a careful verification of repair work is important in order to pick up additional malfunctions that may cause a problem to reappear or a different problem to arise. A blown fuse, for example, is a simple problem that may require more than another fuse to repair. If you don't look for a problem that caused a fuse to blow, a shorted wire (for example) may go undetected.
Experience has shown that most problems tend to be the result of a fairly simple and obvious cause, such as loose or corroded connectors or air leaks in the intake system. This makes careful inspection of components during testing essential to quick and accurate troubleshooting.
BASIC TROUBLESHOOTING THEORY
Electrical problems generally fall into one of three areas:
The component that is not functioning is not receiving current.
The component itself is not functioning.
The component is not properly grounded.
Problems that fall into the first category are by far the most complicated. It is the current supply system to the component which contains all the switches, relay, fuses, etc.
The electrical system can be checked with a test light and a jumper wire. A test light is a device that looks like a pointed screwdriver with a wire attached to it. It has a light bulb in its handle. A jumper wire is a piece of insulated wire with an alligator clip attached to each end.
If a light bulb is not working, you must follow a systematic plan to determine which of the three causes is the villain.
Turn on the switch that controls the inoperable bulb.
Disconnect the power supply wire from the bulb.
Attach the ground wire to the test light to a good metal ground.
Touch the probe end of the test light to the end of the power supply wire that was disconnected from the bulb. If the bulb is receiving current, the test light will go on.
If the bulb is one which works only when the ignition key is turned on (turn signal), make sure the key is turned on.
If the test light does not go on, then the problem is in the circuit between the battery and the bulb. As mentioned before, this includes all the switches, fuses, and relays in the system. Turn to a wiring diagram and find the bulb on the diagram. Follow the wire that runs back to the battery. The problem is an open circuit between the battery and the bulb. If the fuse is blown and, when replaced, immediately blows again, there is a short circuit in the system which must be located and repaired. If there is a switch in the system, bypass it with a jumper wire. This is done by connecting one end of the jumper wire to the power supply wire into the switch and the other end of the jumper wire to the wire coming out of the switch. If the test light illuminates with the jumper wire installed, the switch or whatever was bypassed is defective.
Never substitute the jumper wire for the bulb, as the bulb is the component required to use the power from the power source.
If the bulb in the test light goes on, then the current is getting to the bulb that is not working in the car. This eliminates the first of the three possible causes. Connect the power supply wire and connect a jumper wire from the bulb to a good metal ground. Do this with the switch which controls the bulb works with jumper wire installed, then it has a bad ground. This is usually caused by the metal area on which the bulb mounts to the vehicle being coated with some type of foreign matter.
If neither test located the source of the trouble, then the light bulb itself is defective.
The above test procedure can be applied to any of the components of the chassis electrical system by substituting the component that is not working for the light bulb. Remember that for any electrical system to work, all connections must be clean and tight.
Kevin
