85 three speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2008, 10:39 PM
85 three speed
Hello i have a 85 chevy p/u and it is a 3 speed automatic. There is 1 wire going to the plug on the drivers side. Not being a 4 speed what does the wire do.
Old 10-17-2008, 11:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The wire is power for the converter clutch in the t-350C transmission in the truck.
Old 10-17-2008, 11:19 PM
SSedan64's Avatar
Most likely it has a TH350C with lockup torque converter. The wire goes to the TC solenoid.
Old 10-17-2008, 11:48 PM
RE: 1 wire
Ok thank you . So is 1,2 gears normal and 3 is 1:1 locked up.
Old 10-18-2008, 12:06 AM
SSedan64's Avatar
Yes, TCC only locks in 3rd. Uses a vacuum switch to activate lockup. Also runs through brake switch to disengage.
Old 10-18-2008, 10:54 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
UNLESS, by some odd chance he could possibly have a TH-400 transmission?
If so- then that wire is used for "kickdown", or "passing gear".
I thought the 350C's were long gone by then, and the TH-700R4's were in full production. The 700 started showing up in '82 didn't it?
Old 10-18-2008, 11:09 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
T-350C was used for many years past 1985. I had a 1986 with 350C trans... GM exported the t-350C in various RWD vehicles for several years after they were dropped in t he USA.
We have even seen model year 2000 1/2 ton Silverados with a 5.7 / 350CID cast iron engines with distributors in our shop... these were trucks built for the Mexico market.... in the USA these trucks were all LS engine power.
Although if this truck 1985 was a 1 ton , it may have a t-400 trans in it
Old 10-18-2008, 05:13 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
That's all true, not so much up here in the North, they even had a Dana 44 axle in GM G-body cars headed South out of the country. Wish I could get my hands on one of them.
The 400 could also be had in 3/4-ton trucks as a regular option, and in 1/2-ton trucks up to 1980 as an option too, I had a couple 3/4-ton trucks with the 400 in them from the factory, all were in 3/4 ton.
350 or 383 Stroker? my350camaro84 Engine 19 07-30-2012 08:44 AM
c4 to 5 speed conversion 6t8stang Transmission - Rearend 10 01-11-2005 07:14 PM
Th350 to 4 speed auto conversion Bandit1980 Transmission - Rearend 3 12-29-2004 08:41 PM
Stall Speed? drlindz Transmission - Rearend 2 08-25-2003 03:40 PM
difference in 2 speed to 3 speed auto? HemmiGremmie Hotrodders' Lounge 2 12-17-2002 06:31 AM
