85 vette 700r4 interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2007, 02:30 PM
I've got a bad 700r4 in a 85 vette. Can I put one out of a "caprice" in there while I get mine redone? Will the tailhousings swap?
thanks PH
Old 09-16-2007, 07:24 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
thanks PH
tail housing will swap but......
the vette out put shaft is shorter. you could cut off the caprice output shaft off a bit
the back end of the corvette trans main case is designed stronger for the torque arm mounting. Longer bolts for the tail housing too
junking an 85 K-case 700r4, anything i should save off it ? fast68 Transmission - Rearend 2 07-08-2006 08:05 AM
85 vette, 89 engine,92 body style ...UHGGGG! surferfox72 Engine 2 06-05-2006 05:20 PM
Will A 82 700r4 Fit Into My 85 C-10 Without Problems? hwdponce Transmission - Rearend 4 06-05-2005 07:35 PM
85' 700r4 info GoneNova/406 Transmission - Rearend 4 08-06-2004 01:56 AM
85 camaro 700r4 to th350 drewkuch Transmission - Rearend 5 11-09-2003 10:48 AM
