85 vette - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2006, 06:51 PM
85 vette
has any one ever put a th350 in a vette and still utilized the stock driveline support beam?
Old 05-21-2006, 07:46 PM
airworld2's Avatar
85 vette
are you removing the 700 r4? or a standard transmission? why are you removing either in favor of a 350 transmission?
airworld2
Old 05-21-2006, 10:02 PM
yea it has a 700r4 in it rite now but i just rebuilt the motor >400 hp and i can get it to slip alot and the shifts are getting softer and softer.....especially after hard driving and burnouts.... i want a th350 because in my experience they can be built much stronger and more reliably for a low price than 700r4....and im not concerned with fuel economy because i only get like 5 mpg now with my holley 650 double pumper
Old 05-22-2006, 07:25 AM
Are you familiar with corvetteforum.com? There is a specific C4 section with a lot of knowledge. Try it.
Here's the link:
http://forums.corvetteforum.com/forumdisplay.php?f=34
BTW, did you upgrade the rear?
Old 05-22-2006, 08:03 PM
no its still got the dana 36..... which i think is going to be the next thing to go ...and i found a resonalbly priced 700 on maddogtransmissions that will handle 700 hp so in case i ever want to use it for a different app.
Old 05-22-2006, 08:21 PM
Sounds like fun. But remember, even with a Dana44, your weak link is the universals on the half shafts.
Old 05-22-2006, 10:05 PM
airworld2's Avatar
vett
700 will NOT hold 700 horsepower regardless of what mad dog or any one else will tell you.700 will only hold 400 hp any more than that and parts break and clutch plate failure happens. yea I know the claims out there but on the board here you have Crosley and my self that have pictures on horse power related parts that break. you want over 400 horse power to hit the ground get something other than a 700.
It is only my opinion but the stock parts wont handle the stress and torque but I rebuild them and see what less than 300 horse power breaks.
airworld2
Old 05-23-2006, 11:05 AM
they claim that the internals have been changed out i mean i originally thought that to that they would just com apart with that much horsepower but they say that all the weak internals have been replaced.... and i already replaced the u-joints on the half shafts with much stronger ones garenteed against breakage... what would you recommed for a transmisson?
Old 05-23-2006, 07:52 PM
I think a lot depends on how you intend to use the car. I have a 350/350 in my 38 coupe and I'm quite satisfied with it. It's not a radical motor, but it is built up. The only time I would prefer an overdrive trans is on a longer drive. And that's only to keep the engine revs down.
Here's another place to look for info on the 700R4:
http://www.bowtieoverdrives.com/cata...SUBCAT&CATID=B
Old 05-23-2006, 09:31 PM
yea the only reason i want to stay with a 700 is because the tailshaft that i have to use is not available for a th350 and there is a beam that is used instead of a tranny mount so i will need to extend this because of the shorter th350 ...maybe even elongate my driveshaft
My 73 Vette Story Intrigue Hotrodders' Lounge 13 01-11-2007 08:32 AM
63 Vette Help!!!!! wizzonial Body - Exterior 28 04-27-2006 01:56 PM
Box from a 1995 chevy on an 85 silverado? 85silverado Body - Exterior 0 04-13-2006 12:20 PM
Need help with vette rear in a Mercedes drm184 Suspension - Brakes - Steering 26 01-17-2006 12:23 AM
85' vette wipers and headlights WakBordr7387 Electrical 8 09-05-2005 07:11 PM
