85 z28 rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2008, 04:26 PM
85 z28 rearend
Are the gears in a stock z28 good for a 383 stroker??
I hear they are 3.23s..
Old 07-08-2008, 06:55 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
It depends on your engines' power band, and also the tire size you will be running too.
Your next problem is the simple fact that the axle itsself won't like all that added power, it should be a 7.625 inch ring gear, and they aren't known to last too long with a bunch of power.
If you by chance have the 7.75 inch "Australian" axle, you will be better off swapping it to the 7.625 so you can find parts to replace those that engine overpowers later on.
85 z28 drag car chris oswalt Engine 4 11-23-2004 05:35 AM
Ford 9 in. rearend for 85 Mustang bigblk1177 Transmission - Rearend 2 05-28-2003 07:54 PM
HOW TO remove rocker moulding on 85 Z28? bullheimer Body - Exterior 2 04-30-2003 09:11 AM
85 Chev 4x4, rearend replacement options ssmithpha Transmission - Rearend 0 11-07-2002 06:02 PM
WHich rearend would be better for 85 camaro? stonedchihuahua Transmission - Rearend 1 10-29-2002 05:56 PM
