8500 rpm vs 6500 rpm
I suppose this may sound like a vague question, but what makes one engine capable of 8500 rpm vs one that is limited to 6500 rpm? Is it strictly a matter of better internal moving parts being used? What about shorter stroke vs longer stroke? Is there a limit for a bore/stroke ratio? The following is fairly obvious: proper carb size and fuel supply, single plane intake, higher flowing heads, high perf valvetrain(proper cam, pushrods, retainers, locks, springs, valves, etc...), forged pistons, great rods. Does it come down to "what is the application, race or cruise" and build accordingly? If both are built properly, will an engine designed and built to peak at a higher rpm make more power than the same engine (type, displacement) which peaks at a lower rpm?
To me it seems like you're thinking of it somewhat backwards. You'd build a motor to make power, not to run RPM. If people could get the same horse at 6500 RPM as they could at 8500 nobody would run 8500 because the stresses and costs are much greater. If a motor is set up to run 8500 with proper cam, compression, valving etc and has proper lowers, then yes, it will make more power than a similar motor which is capped for whatever reason at 6500.
Motors become less efficient as they spin faster. Cylinders tend not to fill as completely and frictional losses multiply. Power is defined as work over time, so even if your motor makes slightly less power per stroke at 8500 RPM (assuming it can run 85), you're running 25% more strokes per time unit. Horsepower drops off when your motor's power per stroke drops off faster than what is gained by running more strokes per unit of time. Hope that helps, maybe somebody can explain it better- K |
| Exhaust Diameter Formula | ChevelleSS_LS6 | Engine | 11 | 04-27-2012 09:21 PM |
| 267 small block chevy | chevellecamino | Engine | 59 | 02-03-2012 02:04 PM |
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| 327 in 88 Truck | pete379 | Engine | 101 | 01-19-2006 09:03 PM |
| Raising the Redline | Hollywooding | Engine | 23 | 07-17-2003 10:19 AM |
