Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 8500 rpm vs 6500 rpm
Old 03-05-2007, 04:36 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
peices that can withstand the punishment of rpm's dictate the max rpm. For most engine's, the valve train is the biggest problem.
You need to burn a specific amount of air and fuel to make enough work energy to get the job done. in this case, it's to move a car. You can adjust either the engine's part's parameters like or the RPM, both burn more A/F in the same amount of time.
So smaller engine like fours and sixes need more rpm to do the same amount of work of a bigger engine with less rpm.
A 350 can injest enough air at 9600 with the correct part's to make 650 hp.
A 454 can injest enough air at 5000 with the correct part's to make 650 also.
It take roughly ten times the money to make the 350 live at 9600.
