86 - 305 what cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2002, 04:07 PM
Iroc'o's Avatar
Ernie not Bert
Cool 86 - 305 what cam?
Chevy 86 - 305 (egr) what should be max lift on a cam so as not to disturb brake vacuum or stock converter. Performer manifold also to be added but not much else.
Old 10-09-2002, 05:10 PM
Post
not sure on max lift but have a 305 out of an 83 camaro (was crossram injected)needed a quick motor so i through a set of rings and bearings in it and a cheap Summit 224/234 465/488 cam and was very surprised how the little thing ran
Old 10-09-2002, 05:43 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
I ran that exact cam (was an SSI from PAW) and it did just fine. It still made enough vacuum for the power brakes, but if you hit them more than once, the second time they were noticeably harder. A vacuum reservior took care of that though. Keep the lift, but a little less duration might be just what your looking for.
