86' 351 windsor rebuild help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2010, 08:49 PM
im trying to figure out whats the best combination heads/pistons/cam/intake/carb for the rebuild in my truck(86 f-350).
currently i have all stock parts and i got that whole great water in the oil situation going on so i know its time...plus the owner lied to me and said it was rebuilt but it leaked and didnt run right. i think the differential is a 4:10 gears, 4sp, 4wd if tht helps.
im looking to have more than the original 192 hp that the engine came with. this is my first rebuild and i just want to make sure i get the combination of parts right for about 250 to 300 hp...as budgeted as can be. but i wont cut corners. i guess imjust looking for some guidance. please help with any info: parts, prices, best buys or best places to buy parts. thanks!
Old 07-02-2010, 09:00 PM
just a thought
Zannidave, check out Performance Auto Warehouse in CA. They have been extremely useful to me and my 351 Cleveland. I think the web address is www.pawinc.com and if that don't work for ya, do what I did when I felt lost and just google your motor. I found 100's of sites that contained information that was useful. Fortunately for you the 351 Windsor is a popular motor with plenty of aftermarket parts for you to build with. Keep on truckin'
Old 07-07-2010, 02:33 PM
Some early 351W heads would help you out quite a bit. Aftermarket heads would even be better. Make sure you get pistons to match the heads that you are using so that you can keep your compression down.
Ford 351 C vs chevy 350 eric32 Engine 3 09-18-2009 04:42 PM
buggmann need help puting 351 in a 86 t-bird buggmann Engine 16 04-07-2009 12:06 AM
86 Bronco 351: Installed new carb and now the engine revs to WOT with no throttle Strictly Gravy Engine 7 03-16-2009 06:10 AM
re T-Bird 351 swap. problem solvers Engine 5 09-15-2006 04:27 AM
351 into 86 T-Bird swap problem solvers Engine 10 05-12-2006 11:15 PM
