86 442 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2004, 08:12 PM
My friend has come across an 86 olds 442 for sale
I have not seen this car, but i am told it is in mint condition
This car also has t-tops
I wanted to know if anyone could give me information on this car.
Also what do you think this car should be worth
thanks
Old 06-08-2004, 08:20 PM
DoubleVision's Avatar
I think they came with the F-41 suspension package, 2 tone paint scheme, lightning rod shifters, chrome rallye wheels, a high output 307 cid olds engine (which was still a dead player) a posi rear end. I couldn`t guess what it`s worth without looking at it. these are nice cars, I own a 86 Cutlass supreme, which will look like a 442 when I finish.
Old 06-08-2004, 08:23 PM
poncho62's Avatar
Wiki Edits: 5
If I am correct...they were a "special edition"......
Old 06-08-2004, 08:27 PM
Gimme Gimme!
Rear
3.73:1
Transmission
200-4R 4 speed.
Engine
660CFM Quadrajet
Roller 307
7A heads, A5 intake (if original)
8.0:1
170HP @ 4000
255 Ft Lbs. @ 2400
0-60 in about 7.8
17 sec 1/4
Cutlass/442's can weight in between 3200-3700 pounds.
Depending on the type of 442 (paint sceme, all electric package, dual snorkle air cleaner, suspension, etc.) it can be worth as much as $10,000 or more.
Old 06-08-2004, 09:40 PM
Mirror Image's Avatar
The 86 442 had a auto trans only Hurst cars 1983 and 1984 had lighting rod shifters the rear was a 373 limited slip and the engine was a 307 code 9
Old 06-08-2004, 09:49 PM
77z's Avatar
77z 77z is offline
Go big or go home
3.73 8.5" rear can you say cheap granny rear diff
77 Z28 496 9 inch
10.23 @ 129
Old 06-09-2004, 08:38 AM
Aaaa... No, but I can say expensive 3.73:1 limited slip 8.5" rearend compared to the monte SS cheap 7.625" rearend
Heh.
Old 06-09-2004, 09:23 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
8.5 posi 3.73 is a very desireable rear end. The 8.5s will take a serious beating... the 7.5s on the other hand.... I've seen those snap on the first good burnout.
Huge difference-
K
Old 06-09-2004, 11:46 AM
Im trying to have an idea!
if it is in mint condition with t-tops and low miles, i would say from $4,000 for a low mint car, and top out at $10,000 for a top mint car. if it is a driver car with some flaws, i would give about $2500 with decent miles. i would say go for it. then pull engine (put to side for future worth) and drop a olds 350 or 403 right in. the olds 350/403 are physically the same size as the 307. will bolt right in no complications. paint it black and no will know the difference. you can even use most of your stuff from the 307 on the 350. can even hook up the emission stuff and run it off the computer for a mild olds 350. with the rear gearin and tranny, you will be set for one nice street machine.
8.5 Rear
3.73:1
Transmission
200-4R 4 speed od
Engine
750CFM Quadrajet (can be 800cfm easy)
Roller 307
8.0:1
170HP @ 4000
255 Ft Lbs. @ 2400
0-60 in about 7.8
17 sec 1/4---we have pushed mid 15's with a good tune up on the stock 307
Cutlass/442's can weight in between 3200-3700 pounds. my cutlass supreme is in the 3200 area, had it measured about a year ago, can not remember the exact weight
Old 06-09-2004, 01:11 PM
does anyone know how rare this car is considering it has t-tops?
Also will I be able to smoke some of the 5.0 mustangs and camaros crusin around? And of course those little imports tryin to hotrod around
Old 06-09-2004, 02:06 PM
poncho62's Avatar
Wiki Edits: 5
question 1.............depends how much they leak...they all seem to.
question 2............no
Old 06-09-2004, 02:16 PM
You'll be able to smoke a 3.8, but without at the very least a head swap and intake swap that car falls flat on its face at about about 3000RPM. The 3.73 and extra torque might get you out in front faster though. And yes imports are easy prey
Keep it original, take out the motor and trans and "store them" That car has value!
If anything, find another junker roller 307 HO(vin 9)and swap out the heads and intake, if you find a vin y motor, swap out the camshaft as well. Then the motor wont fall on its face at high RPM.
How many miles are on the thing? The mint garaged cars with only a few miles on them usually sell for the original sale price if not more.
Old 06-09-2004, 03:47 PM
Imports are never a problem.
a good tune and tweek, will beat a stock mustang 4.6-5.0 from light to light. the ss camaros will be a little harder to get to .
I would not waist the time or money on a 307, you will not be able to hit mid 14s if you wanted to. it would be cheaper and about the same amount of work to just drop a olds 350 in there for more power and durability. if you just want a reliable ride just for point a-b, go 307. if you want a reliable power ride for point a-b go with another olds small block, hell id go bigB.
go for it--if its a good deal
Old 06-09-2004, 04:09 PM
Tazz
We arn't talking street racing are we??
Street racing=Big NO-NO here on hotrodders.com don't ya know!! Now, talk about taking that puppy to the track and well yea, blow the doors off that jap crap if ya can!
Tazz
Rat Rods Rule!
Old 06-09-2004, 04:45 PM
i meant to say the theoretical light from light. I DO NOT STREET RACE, THAT IS STUPID AND IMMATURE. and i have seen the consequences of that growing up
