86 454 noise? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2010, 02:17 PM
86 454 noise?
I have a 86 454 in my RV(new to me-had no noise) with 21k miles and a tapping/knock noise. It all started at the end of my first long trip, a 600 mile trip. We pulled off of the highway, almost home and there it was, a tap/knock noise at idle. Good oil pressure, changed oil and filter, added Marvel Mystery, still noise. Adjusted valves, still noise. Everything pointed to a bad lifter. Replaced all lifters, still noise. I had changed the mech fuel pump before the trip (just in case) so I thought maybe it was bad. The rv has 2 pumps, one electric back by the tank and the mech on the engine. I removed the pump shaft for the mech pump and still the noise. Checking this website, the last hope was loose flywheel bolts. All tight but.....I tried to run the engine when the converter was unbolted and the noise is gone!!! Problems in the tranny but what? It seems to be a th400 or th475, 13 bolts on pan. Any ideas? Joe
Old 09-19-2010, 02:48 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You need to check the flywheel for cracks, I have seen a cracked flywheel do this. JMO
Cole
Old 09-19-2010, 05:40 PM
hard to believe?
Cole,
I'll check it again tomorrow but let's say it's a cracked flywheel, how is the noise being made? I would think for a cracked plate to make that kind of noise I'd have seen a distortion of the flywheel. I'll post soon.
Thanks, Joe
Old 09-19-2010, 05:45 PM
lookatme's Avatar
the flywheel cracks around the center bolts, and what you hear is the flywheel beating against itself as it flexes. you wont see much if any distortion. and you have to look really hard for the cracks.
Old 09-19-2010, 07:38 PM
eloc431962's Avatar
Wiki Edits: 37
X2 What he said.
Cole
Old 09-22-2010, 07:15 PM
What do you guys think about this?
Ok, I inspected the flex plate and couldn't find any cracks anywhere. I did find that the flex plate and the whole crankshaft can move forward and back about 1/4". I can do this by prying the flex plate away from the rear of the engine and then grabbing it and pushing it forward. That doesn't seem right at all. The manual says the thrust bearing clearance should be .003" so 1/4" is way too sloppy. I didn't find anything on this website but another site suggested "converter balloning". They suggested a build up in trans pressure from a clogged/restricted cooler line could cause this. I guess if the converter can expand and push on the rear of the crank, I guess the weak area is the crank's thrust bearing. I'm guessing the motor is shot. Unbolting the converter and running the engine allows the crank to find a place where what ever is hitting internally, to not hit. Does this sound right?
Old 09-22-2010, 09:07 PM
lookatme's Avatar
you need to check the areas of the flywheel just outside of the crankshaft bolt circle. look for tell tale rust. take a knife and run it from the center of the flywheel to the outer edge. also around the crank bolts. if it catches. you found a crack. they are hard to spot. the crankshaft moving back and forth could of caused the flywheel to break. if it is the thrust bearing, all youre out is a set of bearings and a crank.
Gen6 Vortec 454 Need help before its gone!! 973kgt Engine 3 03-31-2010 05:53 AM
need help with my 454 build black_chevy Engine 9 12-09-2009 04:22 PM
Turbo 400 ex 86 - 88 Duallie 454 opelitis5 Transmission - Rearend 7 07-10-2009 07:07 AM
40 Merc steering noise (weird) Da Hellion Suspension - Brakes - Steering 6 01-02-2006 09:41 AM
Squeezing a little more power out of my 454 RObs71Nova Engine 8 05-21-2005 03:38 PM
