86-87 monte carlo ss 350 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2009, 12:57 PM
do i need to use a specfic year motor for it to work under there?? i want to end up with a nice 383 and a 700r4. i did a 93 fox swap from a 4cyl to a 347 several years ago wasnt that bad. any advice on what would the easiest route would be a huge help.
Old 11-02-2009, 02:28 PM
Wraith's Avatar
Born to lose,living to win
I would go with a 6L FI swap and run a T56 but it can be pricey.
Old 11-02-2009, 04:01 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You can put any SBC in there everything should work just fine, What year engine are you thinking about going with? Whats it got a 305 now? .................Cole
Old 11-04-2009, 08:00 AM
its got a 305 ho. i want to have 400-450 hp 383. using the 305 heads a nice cam that work well with juice and a 700r4 with a 3400stall.
Old 11-09-2009, 07:52 PM
SSedan64's Avatar
The 305 L69/HO heads will need some port work to help them breath on the 383. A set of 96-99 Vortec heads would be better if your budget allows.
A TH2004r trans would be a better fit/choice since that's what came in 85-88 SSMonte's. It would save you Crossmember & Driveshaft Mods also.
Lots of good SS Info here>> http://www.montecarloss.com/general.html & http://www.montecarloss.com/technical.html
Old 11-13-2009, 04:59 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
The ONLY thing you have to make sure of is 55-85 small block take 1 flexplate, 86-up take an external balanced flexplate, and the 383 may take one from a 350 OR 400, the 400 flexplate was an external balance piece.
I have never really checked into whether the external balanced 400 and 454 flexplates were balanced the same as the 86-up 305 and 350 pieces, but they may have the same balance weights, I'm not sure. All might just be different to their own, I know 86-up 305, 350, and 4.3 V-6 pieces will interchange.
monte carlo ss MDot Transmission - Rearend 7 09-28-2009 04:19 PM
87 Monte Carlo wiring in a 76 350 mightycarlo10 Electrical 9 03-27-2008 11:09 PM
Swapping a 350 into a 77' Monte Carlo ?. chevy350_Camd Engine 5 02-20-2008 10:19 AM
Any Value To A 1971 Monte Carlo 350 Engine daveh Engine 18 01-09-2008 09:49 AM
axles for 86 monte carlo Jooooooe Transmission - Rearend 6 01-06-2002 07:21 AM
