86 c10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2013, 12:06 AM
cabrez99's Avatar
86 c10
What's everyone.
I own an 86 Chevy C10 Pickup, the current issue that I am experiencing with the truck is that during cold start, it starts at one crank, idles fine and runs fine, but after driving the vehicle for example to the store. I shut of the truck, do what I need to do and then when I turn the key, it won't turn over. I would have to wait for about 30 minutes or so before it decides to turn over. Its frustrating having to wait that long before it can crank over, for some reason something in the engine external components has to cool down, does anyone have any idea what this is caused by.
Your help will be greatly appreciated.
Old 06-19-2013, 12:37 AM
Banned
no crank hot, look at starter selniod
crank but no fire, boil'n fuel in carb
Old 06-19-2013, 07:22 AM
RWENUTS's Avatar
You're getting heat soak in your starter/solenoid. Common with chevy's. Try this. It works.
Remote Starter Solenoid Instructions
Old 06-19-2013, 07:05 PM
cabrez99's Avatar
I figure it was the starter at first because I had to tap the solenoid while my wife cranks the engine and it started. That was my next option was to run a remote starter. As for the boiling fuel in the carburetor i've check it, but nothing noticed.
Keep you all update if any changes or problem solved.
Thanks
fitting 1972 c10 brakes on a 1963 c10 hman17024 Suspension - Brakes - Steering 3 04-09-2013 08:20 AM
C10 Eddiec10 Hotrodding Basics 0 03-27-2012 12:18 AM
Oz 68 C10 Piknup Introduce Yourself 1 01-31-2012 03:45 PM
82 c10 cheese burger Hotrodding Basics 7 10-27-2011 11:02 PM
78 c10 VicentJackle Introduce Yourself 3 12-30-2005 10:14 PM
