86 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2011, 09:44 PM
86 camaro
1986 camaro slipping transmission, 2.8 liter. do i replace with similar or something different? i have 5.0 engine & transmission from 1987 fire bird.
Old 05-19-2011, 08:36 AM
It would be best for you to hit the thirdgen.org forums.
You'll have to do some rewiring to get that 5L in there the way the factory intended (incidentally is that a TPI, TBI or Carby?)
As far as the trans its best for you to probably pull your engine and trans as a unit and replace with the 5L and a later-than-1986 700r4, in order to minimize downtime.
93 Camaro converted to 96 Camaro LT1? tylerwerrin Engine 1 09-01-2010 09:54 PM
93 Camaro converted to 96 Camaro LT1? tylerwerrin Engine 0 09-01-2010 07:56 PM
79 camaro hood hinges to 71 camaro swap Gladis Body - Exterior 1 01-10-2008 02:17 PM
Will a Tilt Column from 70-81 Camaro fit 69 Camaro? dpjmw Suspension - Brakes - Steering 2 07-04-2006 10:27 PM
72 camaro nose on a 78 camaro roy383ci Body - Exterior 3 02-25-2006 05:59 PM
