86 camaro stall - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-22-2012, 12:58 PM
F-BIRD'88's Avatar
Yada Yada Yada
possible idle air control motor fault.
Possible throttle position sensor (sensor fault or needs adjustment setup.)
possible temp sensor fault.
very probabile simply just the wrong incompatible camshaft.
( hunting idle and stalling)
remember the previous owner sold it for a reason.
If you do not want to register, fill this field only and the name will be used as user name for your post.
1989 Camaro with a 1969 camaro rear will it look good??? Opinions!! nealey101585 Hotrodders' Lounge 63 06-23-2012 03:03 AM
new video up/ 67 Camaro painted/ red Camaro gets the boot tech69 Hotrodders' Lounge 7 04-21-2012 11:10 AM
camaro sbc 350 stall issues kax1978 Engine 2 03-07-2012 08:53 AM
High stall or low stall neverending Transmission - Rearend 12 02-26-2007 08:28 AM
CAMARO engine STALL Ramzes1 Engine 8 01-27-2004 04:04 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
