86 Camaro Trunk Lid Motor Stuck! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2006, 10:05 AM
I have a 1986 Camaro with an electric trunk/window lid...push it down and the motor takes over. You can access this motor easily with the trunk lid open, but my motor is shot (for sure it is the motor). So...the trunk sits closed tight, and someone installed the wrong key tumbler so the actuator doesn't work...only the auto trunk button on the console worked. Now that the motor is shot, nothing works.
Long story made simple: How do you open the lid without power? After crawling around back there, I figured I'd ask before cutting things.
Old 04-15-2006, 05:23 PM
73oldsman's Avatar
Can you access the trunk area by pulling the back set and crawling through?
Old 04-15-2006, 05:37 PM
jajeff22's Avatar
the 377 rocks
Last journal entry: my 68 camaro
have you tried the reset button in or behind the passenger side back panel. i know they had that in a 89 . you might have to crawl over but it did the trick for me.
Old 04-21-2006, 06:30 PM
73oldsman's Avatar
Paging Buickguy! Did you get in your trunk yet?
Chevy trunk lid paishman Body - Exterior 1 03-22-2006 12:04 PM
Replacement doors and trunk lid paishman Body - Exterior 0 02-05-2006 07:47 PM
Trunk Lid Latch/Lock for 28 Ford Doc68 Body - Exterior 2 11-10-2003 10:33 AM
DAD IN NEED OF DIRE HELP! (86 Camaro) veg_eta_ble Engine 3 04-21-2003 06:58 PM
real dual ex pipes headrs back 86 camaro methuenyankee General Rodding Tech 5 03-17-2003 11:05 PM
