86 Chevrolet Hydraulic Clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2011, 08:40 AM
I am having trouble with my clutch pedal. I replaced the slave and master cylinder and was able to get it bled. The issue i am having is the clutch does not engage until the pedal is almost clear out. Is there a way to adjust this setup so the clutch engages sooner?
Old 02-06-2011, 10:32 AM
DoubleVision's Avatar
Not that I know of. Every Hydraulic clutch I`ve ever used engauged almost at the top of the travel. You get used to it after a while.
Old 02-06-2011, 11:56 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Maybe adjusting the pedal travel would give it a better feel for you, but like DV says, it's probably normal.
Old 02-06-2011, 12:54 PM
bigdog7373's Avatar
Of course it's fast
Can you adjust the pedal at all? So it engages when the pedal is closer to the firewall? Maybe a custom bracket?
Old 02-06-2011, 12:59 PM
I wondered about shimming the slave cylinder out some also. Thanks for the replies
Old 02-06-2011, 03:49 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Rather than shim the SC, you could shorten the push rod...
Old 02-06-2011, 03:56 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Moving to the brake forum.
Old 02-06-2011, 04:33 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Sounds more like the clutch is wore out. Did you have the same problem before you replaced the hydraulics?
Hydraulic Clutch Thirty Seven Ply Transmission - Rearend 6 05-17-2007 09:01 PM
hydraulic clutch TBear Hotrodding Basics 9 10-30-2006 05:51 PM
Hydraulic Clutch Blazin72 Transmission - Rearend 5 03-31-2006 08:47 PM
Hydraulic clutch fred56 Transmission - Rearend 5 09-28-2005 05:34 PM
hydraulic clutch martion Transmission - Rearend 9 03-26-2003 01:37 AM
